Migrating Data to New Systems with APIsIn the first two posts in this series, we looked at what APIs are and how to use them to move data in the cloud. In this third post co-authored with one of our data experts, De Wet van Niekerk, we’re going to dive into the details of migrating data via APIs through one of our own system migration examples. Part 4 details how and why to build your own API.
At Safe, we are always looking for ways to improve our customer service, and we recently upgraded our user community to provide a new Knowledge Center where FME users can ask questions, access resources, and submit ideas straight to our developers all in the same place.
Our old system used a combination of Salesforce and Trello, and APIs made it possible for us to move all of our data to our new AnswerHub community — without losing a thing.
Understanding Requirements and Challenges
Migrating data between services can be a complex process. And one of the most challenging parts is understanding the data models to construct an accurate mapping. But the good news is once that’s finished, flexible data transformation tools, like FME, make the actual migration very straightforward.
Three main tasks needed undertaking in our migration:
  1. Moving over 1,500 knowledge articles and 3,000 Q&As from Salesforce
  2. Mapping ideas submitted from customers on Trello boards to the Ideas component in AnswerHub.
  3. Making it possible for users to sign-in to the whole site with one login using Auth0 for site-wide authentication. To achieve this, user information needed to be loaded to both AnswerHub and Auth0 for sign-in to work automatically.
FME User Community Migration
General Data Migration Challenges
1) Connecting to the APIs — Authentication
To access services, you first need to determine the authentication mechanism: token, OAuth2 or maybe HTTP Basic. And each service usually interprets the standard slightly differently. For example, with token based authentication, does the token go in the query string or in the header?
The complexities around authentication, especially if the service is using OAuth2, make it one of the biggest barriers for working with web services. But thankfully FME supports OAuth2, token and basic authentication — so once we worked out the intricacies of authentication for the three services, we were able to set and forget in our FME data transformation workflows.
2) Creating Repeatable Migration Process
A major difference between loading data via API calls and a direct read-and-write method is that the loading process can easily become a multi-phase process. One piece of data can be loaded and the resulting object, now immediately available through the API, can be used in the next phase of the migration. This does require a bit of a shift in approach; creating a repeatable migration process is more about defining a set of steps than about mapping out an exact target dataset.
For example, once a Q&A question was loaded into AnswerHub, its URL was returned in the response header. From here, we could extract the URL and use it to post comments and answers to the question.
3) API Errors
API errors are a fact of life. They can be caused by network timeouts, improperly formatted requests, or various server errors. At a minimum, it’s important to log these to confirm that information doesn’t get lost. Ideally, it is possible to identify what caused the error and resubmit the requests with only the failed content. Again, thankfully, we were able to configure this in our transformation workflows.
Data Specific Challenges
Every migration is unique, and for this particular example, we had a different set of challenges for each set of data we had to load:
1) Loading Users
Users had to be loaded to Auth0 and AnswerHub from Salesforce and Trello. There were several challenges:
Salesforce to Auth0
2) Loading Knowledge Articles
All existing Salesforce Knowledge Base articles needed to be migrated to the new site. Some of the challenges encountered:
3) Ideas
Ideas were pulled from two existing Trello boards into AnswerHub’s Ideation system. Trello is a general-purpose tool for visual organization, while Ideation is specifically targeted to getting customer feedback, and indicating progress on implementation of ideas.
Challenges with this migration:
Trello to AnswerHub
4) Question and Answer Site
The question and answer site was the most complex to migrate:
Migrating the Data
Reading, cleaning and loading Trello Ideas and Votes into AnswerHub via APIs
After identifying our requirements and understanding the data models, we developed several workflows in FME that connected to Salesforce and Trello via APIs, transformed the data as it was migrated, and loaded it into AnswerHub and Auth0 via API calls.
Key Transformers Used
FME transformers are used to read data into the workflow, validate the data and correct it. Several key transformers were used when undertaking this bulk migration:
Connecting to Various APIs
Authentication is a crucial part of working with APIs. FME allows you to authenticate via token, OAuth 2.0 or HTTP Basic which covers the most popular forms.
Instagram API Authentication
Authentication Example: FME connecting to the Instagram API using OAuth2
While designing the migration workflow, we tested out our ideas in a staging environment. When we were satisfied everything was running smoothly, we switched the target over to the production environment. Rather than carrying out the tedious task of changing the URL, username and password in every HTTPCaller, the URL was set to a published parameter, and the authentication information was stored as a web service. This has several advantages:
Assessing the Result
APIs give you the flexibility to choose the best services for your needs. In our migration example, we successfully moved data from Salesforce and Trello into AnswerHub/Auth0 and upgraded our user community to provide even better customer service.
The key takeaway? You’re never stuck in one system. With APIs and data transformation technology to get your data exactly how it’s needed, you have the freedom to choose whichever services are best for your needs.
Learn More About APIs
In the next and final blog post in this series, we’ll discuss how to build an API on top of FME without writing any code (and why you’d want to).
To learn more about connecting to APIs to access, migrate, and integrate data with FME, check out our API webinar. And as always, if you have any questions or thoughts on this post, please share in the comments.
About Data API Knowledge Center Salesforce
Stewart Harper
Stewart is the Technical Director of Cloud Applications and Infrastructure at Safe. When he isn’t building location-based tools for the web, he’s probably skiing or mountain biking.
Comments
Leave a Reply
Your email address will not be published. Required fields are marked *
Related Posts
