BigDataToCloudFME Cloud has been live for over 18 months now, and one of the biggest hurdles customers face is moving their datasets into the cloud—particularly if they are large. Below are the three main data upload challenges we see.
Most scenarios we’ve seen involve loading data up to Amazon Web Services (AWS), since FME Cloud runs on AWS, but these techniques also apply to loading data into other cloud platforms such as Microsoft Azure.
Small Datasets Frequently
To upload small datasets at frequent intervals, you can leverage a number of tools provided by AWS and third parties. The following solutions all use HTTP, which should be sufficient unless your internet connection is really unreliable.
Large Datasets Infrequently
Here you can use the AWS Import/Export service or the similar service offered by Azure.
How it works: you load your data onto SSD disks and post them to Amazon, then they load your data into a nominated S3 bucket or EBS mount. It is an excellent way to do a bulk upload if you plan on doing change-only updates.
If loading your data over the network would take 7 days or more, definitely consider using AWS Import/Export. First, it’s cost effective, as you don’t have to pay for bandwidth costs, only a handling fee and $2.49 per loading hour. Second, it’s secure: you can use pin code and software encryption to ensure your data is secure when it is in transit. Finally, your data is guaranteed to load within 1 business day of receiving it, so it is a relatively fast way to load large datasets.
Large Datasets Frequently
This relatively common scenario is the trickiest of all three. Often people leverage the scalability and cost of the cloud to process large data volumes, and if the data originates from outside the cloud, they need to push it up in an automated way. Examples we run into involve LiDAR and Raster data. One client had to upload 12GB of satellite data every 12 hours, and it was time sensitive so it needed to be uploaded as quickly as possible.
To upload large volumes of data the standard tools AWS offers are often too slow, even if you have a fast internet connection, as they all rely on HTTP. There is overhead with HTTP because it relies on the TCP protocol, which simply wasn’t designed for moving large datasets across the WAN.
Accelerated file transfer solutions have come to market that leverage UDP, which can facilitate much greater throughput by using more of your available bandwidth and is less affected by network overhead. Several accelerated file transfer solutions exist. This list is by no means exhaustive, but here are a few:
Comparison of data upload tools
I ran a variety of tests uploading data to S3 using both commercial and open source tools. Two datasets were uploaded: one was a 10GB single file, the other a series of folders with 21,000 images in it. The uploads were tested on two internet connections: one a fibre connection with upload speeds averaging around 170Mbps, the other a broadband connection with an average upload of 2.67 Mbps. Here are the results.
FME
(HTTP)
CyberDuck
(HTTP)
Aspera
(FASP)
Upload Speed 170Mbps
Total 10GB – Single file 9m 24s Failed 443
failed to respond error.
 9m 5s
159.1 Mbps
Total 5GB – 21,000 web map tiles  12m 31s 1h 24m  57m 36s
14.3 Mbps
Upload Speed 2.76 Mbps
Total 10GB – Single file FailedTimeout Issue  9h 57m  9h 36m
2.5 Mbps
Total 6GB – 21,000 web map tiles  FailedTimeout Issue  7h 6m  5h 41m
2.44 Mbps
Speed
Aspera comes out on top in most speed tests—although the speed gains were not as large as I expected. FME was not far behind Aspera on uploading the single file and it was faster at uploading the 21,000 map tiles. This is likely because we just switched to the new SDK and we now leverage a folder upload API call. (Note: I also had a note from Aspera support highlighting some tweaks that can be made to improve the upload speed, but haven’t had chance to try it.) FME also had timeout issues when I uploaded on the slow internet connection… we will get this fixed.
I think FME was so close to Aspera (and CyberDuck in some tests) because I was testing in optimal network conditions. Data was getting copied from Vancouver to Virginia so the data stayed on the North American continent, likely resulting in low latency and reduced packet loss. Indeed, Aspera logged the network delay as being only 67ms. If you try to upload data in more marginal network conditions or to a server on another continent I think the speed difference between solutions using HTTP and UDP will be more apparent.
Ease of use
Aspera is a bit fiddly to set up (although they have excellent support), but it is a comprehensive solution and has a lot of very useful features. To set up you have to run your own AWS instance and install their software on it. So in that sense it is another piece of infrastructure you need to monitor and maintain. The features I found most useful included a dashboard giving an overview of current and recently completed uploads, granular control on how much bandwidth to assign to the upload and the ability to review uploads after they had completed with statistics on speed of upload and when it was delivered.
I also had a brief look at FileCatalyst and it was simple to set up and configure but the available supporting tools weren’t quite as rich as Aspera. The Web UI also wasn’t quite as usable. It uses the same design pattern with their software running on an AWS EC2 instance that you manage.
FME is also easy to use with a drag-and-drop interface. The workflow I built to upload to S3 took me less than five minutes. We also have tools for uploading, deleting, downloading and extracting meta data from S3.
Using the S3Uploader FME transformer to upload a Point Cloud file to AWS S3.
FME workflow: using the S3Uploader transformer to upload a Point Cloud to AWS S3.
CyberDuck is just like an FTP client where you drag and drop files you want to upload. Once connected to a bucket you can also delete and move files.
What accelerated file transfer solutions have to offer
I started this review thinking the performance increases offered by accelerated file transfer solutions would be the main benefit. It turns out the greatest benefit was reliability, and essentially turning file upload into a fault-tolerant component. Often we design complicated fault-tolerant architectures in the cloud, leveraging all AWS has to offer to ensure we have a stable, reliable application. However, such a design is only as strong as the weakest link. If you are relying on data being uploaded to the cloud to trigger a workflow, my bet is that it is likely to be the weakest link. If uploading files is an integral part of your workflow, I suggest taking a look at the commercial accelerated file transfer solutions.
For most users, the performance you get from FME will be sufficient for uploading files to the cloud. If you are uploading incredibly large files over a poor connection you may run into issues, but I would start my benchmarking here. Give FME a try and let us know what you think. What is your biggest data upload challenge?
About FME Big Data Data Upload FME Cloud FME Server
Stewart Harper
Stewart is the Technical Director of Cloud Applications and Infrastructure at Safe. When he isn’t building location-based tools for the web, he’s probably skiing or mountain biking.
Comments
3 Responses to “How to Upload Big Data to the Cloud”
  1. Peter Barnes says:
    Apologies if this sounds like a plug for business – it’s meant to be a community service announcement.
    For those of us in Australia, where AWS Import/Export is not yet available, Geomatic Technologies can provide a portable media handling and upload/download service. It’s not totally free, but as our Direct Connect and intecap comms are supported by other business and any excess is pay-per-use we can often do import/export for others at cost. No SLAs etc. on the cheap-and-cheerful service, we’ll just fit your job in when we can. We have many storage devices zooming about domestically and overseas, and have made a solid contribution to AWS’s profits via inter-region transfers that can run for weeks, so are well versed in how painful big spatial (especially image) data logistics gets!
    If you have portable HDDs or NAS, and >1TB of data that you want to get in/out of ap-southeast-2, give us a call and ask to speak to Mark Deady or myself. Contact details on the website.
    regards,
    Peter
    • Tiana Warner says:
      Hi Peter,
      Thanks for letting us know about your data upload/download service. Every cloud user has different requirements so it’s great to be aware of all the potential solutions out there for data import/export.
      Cheers,
      Tiana
      ______________________________________________________
      Tiana Warner | Technical Communications
      Safe Software Inc.
      Suite 2017, 7445 – 132nd Street, Surrey, BC Canada V3W 1J8
      http://www.safe.com
  2. […] GIS Office – DATA Safe.com: FME Cloud Safe Blog: How to Upload Big Data to the Cloud Recorded Webinar: Introduction to FME Cloud + […]
Leave a Reply
Related Posts
