FME Server 2018.1 Tour and Examples
Learn the basics. No download required.
Welcome
FME Server Web Interface
Publishing a Workspace to FME Server
REST API
Example 1
Step 1 of 4
Step 2 of 4
Step 3 of 4
Step 4 of 4
Example 2
Step 1 of 3
Step 2 of 3
Step 3 of 3
Example 3
Step 1 of 5
Step 2 of 5
Step 3 of 5
Step 4 of 5
Step 5 of 5
Example 4
Step 1 of 4
Step 2 of 4
Step 3 of 4
Step 4 of 4
Example 5
Step 1 of 4
Step 2 of 4
Step 3 of 4
Step 4 of 4
Example 6
Step 1 of 5
Step 2 of 5
Step 3 of 5
Step 4 of 5
Step 5 of 5
Next Steps
Everything starts in the FME Server web interface. Access it via the URL you configured during setup, or if you’re using FME Cloud, via the URL of your cloud instance.
This tour demonstrates common automation scenarios, including running FME workspaces on demand, setting up schedules, and creating triggers.
Tour the FME Server web interface in more detail on the FME Knowledge Center.
Go to Tutorial
The first step to automating an FME workspace is to publish it to FME Server. This tour assumes basic knowledge of FME Desktop, the authoring environment for workspaces.
Start by opening your completed workspace in FME Workbench. In the top toolbar, click Publish to FME Server.
Choose your FME Server Connection from the drop-down list (if this is your first time connecting to your FME Server instance, set up the connection by clicking Add Web Connection). Click Next.
Select or create the repository you want to publish the workspace to. Click Next.
Check the services you want to use. This depends on what you want to do with the workspace. Click Publish.
You can now access your FME workspace in the FME Server web interface. Continue with the examples in the left sidebar to learn how to perform specific automation tasks.
REST API
The FME Server REST API provides methods to control a range of FME Server functionality. This is a more advanced way to use FME Server.
Explore live demos and get started with the FME Server REST API.
Go to FME Server Developer Playground
Overview
In this exercise, we’ll publish a workspace to FME Server and run it from the FME Server web interface. Click Next to get started.
Step 1: Publish Workspace to FME Server
Publish your workspace to FME Server using the steps outlined in the FME Server Basics section above. In the last dialog window, check the Job Submitter service.
Step 2: Run Job in FME Server
Go to your FME Server web interface. In the left navigation pane, click Run Workspace.
Select the published workspace using the Repository and Workspace options. Under Service, click Job Submitter. Click Run.
Step 3: View Completed Job
Click View Details to see the log file for the completed job.
You Did It!
Well done. You published a data loading workspace to FME Server and ran it on demand.
Explore this example in more detail on the FME Knowledge Center. Go to Tutorial
Schedule a Job
In this exercise, we’ll create a schedule to automatically run an FME workspace on a daily basis. Click Next to get started.
Step 1: Create a New Schedule
Go to the FME Server web interface. On the left navigation pane, click Schedules. On the top right, click New.
Step 2: Configure Schedule
Give your schedule a Name, Category, and Description. Define how often you want the job to run. For this scenario, we will check Run Immediately and set it to repeat every 1 Days. Under the Workspace section, choose your repository and workspace. Click OK.
You Did It!
Well done. You created a schedule to automatically run your FME workspace once a day.
Go to Tutorial
Create a Data Download Service
In this exercise, we’ll enable end users to extract data on demand. Click Next to get started.
Step 1: Build FME Workspace
To create a data download service, start by building an FME workspace that converts to the desired data format, and expose the parameters you want the end user to be able to control. For this scenario, we’ll expose the Source and Destination File, File Format Extensions and Coordinate System parameters so the end user can control the translation.
Step 2: Publish Workspace to FME Server
Publish the workspace to FME Server using the steps in section 1.2 above. Upload the Data Files. Check the Data Download service in the last dialog window.
Step 3: Run a Job in FME Server
The following steps show how the end user can run the data download job.
Go to your FME Server web interface. In the left navigation pane, click Run Workspace. Select the EasyTranslator workspace in the Samples Repository. Under Service, click Data Download.
Choose the parameter values. Click Run.
Step 4: Download the Results
Your results will be available as a URL after the job finishes. Click the URL to download the data.
You did it!
Well done. You published a workspace to FME Server and enabled it for Data Download. Now any user can download this data through the FME Server web interface.
Go to Tutorial
Monitor a Directory
In this exercise, we’ll create a directory watch notification to monitor a directory in the FME Server Resources for new files. Click Next to get started.
Step 1: Create a New Publication
In the FME Server web interface on the left navigation pane, click Notifications. In the Publications tab, click New.
Step 2: Configure Publication
Give your publication a Name, set the Protocol to Directory Watch, and choose/create a Topic To Publish To. Configure the Protocol Settings with the directory you want to monitor, and the action(s) you want to get a notification for. Click OK.
Step 3: Verify the Directory Watch Notification
On the Notifications page, go to the Topic Monitoring tab. Under Topics to Monitor, select the topic you created. Click the Play button to start monitoring.
Test your workflow by adding a file to your monitored directory. A message will appear in the Topic Monitoring tab.
You did it!
Well done. You created a directory watch notification and configured it to monitor a folder. Now FME Server is ready to trigger an action whenever a file changes in the FME Server Resources.
Go to Tutorial
Receive an Email
In this exercise, we’ll create set up FME Server to receive emails. Click Next to get started.
Create a new publication
Configure publication
Give your publication a Name, set the Protocol to Email (SMTP), and choose/create a Topic To Publish To. Configure the Protocol Settings with the Email User Name. Click OK.
Verify the Email (SMTP) notification
Test your workflow by sending an email to your FME Server (if it is publicly accessible). The email address will be Email User Name@FME Server hostname.
You did it!
Well done. You created an incoming email notification. Now FME Server is ready to trigger an action whenever an email arrives.
Go to Tutorial
Trigger a Workspace
In this exercise, we’ll create a notification that runs the AustinApartments.fmw when a topic is triggered.
Create a new subscription
On the Notifications page, go to the Subscriptions tab. Click New, then select Workspace as the protocol.
Configure subscription
Give your publication a Name and choose/create a Topic Subscribed To. Configure the Protocol Settings with your connection details, the directory you want to monitor, and the action(s) you want to get a notification for. Click OK.
Trigger a topic
Use either the Directory Watch or Receive an Email options to trigger a topic (ReceivedEmail or DirectoryWatch topics) that the workspace is subscribed to.
Check the job ran
View the Completed Jobs page to check that AustinApartments.fmw ran.
You did it!
Well done. You built an FME workspace that automatically runs a workspace when a topic is triggered.
This can be the directory watch or incoming email (or any other publication).
Next Steps: Free FME Training!
We want to help you learn FME, so all of the online training provided directly by Safe Software is free of charge.
On-Demand Training
Watch videos as our FME Certified Trainers take you through our course exercises.
Live Online Training
Take our full FME Desktop course free of charge, complete with virtual machine and live Q&A.
Tutorials
Access a range of getting started tutorials in our Knowledge Center.
