Hi FME’ers,
In a previous Evangelist post (from 2012) I talked about nulls in data and how FME handled them. In 2014 we have exciting new functionality that deals with null values in a proper way.
Because we’ve changed how FME behaves, if you think your source data may contain nulls then it’s important you read this article.
EvangelistBanner7
You were nothing to me once, and I was contented; you are now nothing to me again. But how different the second nothing is from the first! – Thomas Hardy in Far From the Madding Crowd critiques our new functionality!
EvangelistBanner7
Nulls in General
First let’s recap what we mean by null. In general there are three types of ‘nothing’ values:
I say ‘three’ types, but really there are many more. A numeric attribute with a value of zero could be taken to mean nothing. Also there are NaN (Not-A-Number) values, nils in XML, Nodata values in raster, and many others (did you know Excel has its own special version of ‘nothing’?) – in fact I’m told by our developers that they found fifteen (15) types of nothing; but here we’re looking at the three primary types of nothing and why null is special.
NullsWarpingData
Yes, fifteen types of nothing! When you get all of them in a single dataset it causes a vortex in space-time! True.
But for most people nulls will occur in a database. A true null means a field has been deliberately set to ‘nothing’. It’s not the same as an empty value at all. The closest non-IT analogy I can think of is when you fill in your name on a questionnaire. You could fill in your middle name (in which case it has a value) or you could write “n/a” or cross the field out. That would be equivalent to an empty field; it’s a positive value and we know you have no middle name. However, if you left that field blank, that would be a null; we can’t tell whether or not you have a middle name. It’s a value that signifies “unknown”, sort of a placeholder for real data.
EvangelistBanner7
Nulls and FME
Up until now FME did not have explicit support for nulls; we supported empty values and non-existent attributes (plus other forms of nothing, like NaN) but null wasn’t a concept that our internal data model understood. If an attribute was null then it was treated as if it didn’t exist. However, in 2014 we’ve completely overhauled that data model to incorporate null value support. So FME can now read null values, write null values, and carry out transformations on them too.
In terms of databases, it means you can now much more easily identify values that are null and write nulls to new rows, plus change existing rows to be null (which you couldn’t do before).
DifferentFormatsDifferentNulls
But, like people, formats come in all shapes and sizes and no two are the same. Interestingly, some formats will support all three of our primary nothing types; some will support just one or two. For example, Shape supports empty values, but not nulls, whereas GeoMedia supports nulls, but doesn’t recognize empty values. Databases generally store both null and empty values, and let you query them too. JSON nicely supports the concept of all three, whereas VPF has at least five types of nothing, maybe six depending on the field type (getting close to a space-time ripple there)! So even with null support, the behaviour of FME’s Readers and Writers will vary according to format, and you have to be aware of that.
EvangelistBanner7
Reading and Writing Nulls
If your source data includes null values the FME Reader will now emit null values. You don’t need to update or replace the Reader in your workspace, it will happen automatically. When you write the data out then the Writer will write null values too. If the format you are writing doesn’t support nulls, then the data will be handled appropriately – replaced with zero, or an empty value, or whatever that format requires.
So a translation involving nulls should just work. You don’t need to do anything special to your workspace, even if it’s an older one.
Which formats does this apply to? I’ve created a list at the bottom of the article for you to check, and you can find that list on FMEpedia too. We cover all the major databases, but if there’s a format you think we’ve missed then please do let us know.
EvangelistBanner7
Data Inspection
So now nulls have been incorporated into the FME Data model, we need a way to inspect the data, and a way to distinguish true nulls from other forms of “nothing”.
When you use the FME Data Inspector to examine your data before translation (you are inspecting your data before translation, aren’t you?) you’ll see null values displayed in the table view:
NullTableView
…and in the Feature Information window:
NullFeatureInfo
When an attribute exists, but is empty, the Table View window will show it as an empty field (i.e. the cell in the table is blank) but when the attribute is missing completely (i.e. just doesn’t exist for that feature) then it flags it as such:
MissingValueTableView
Here TaxCoord is part of the source schema, but these features don’t have it at all. So now you can totally identify which attributes are null, which are empty, and which are missing.
EvangelistBanner7
Nulls and Transformers
OK, so if we’re reading this data, and have an internal representation, then we also need a way for you to handle it in Workbench. Therefore we’ve updated several transformers to specifically handle nulls, updated many others to simply cope with null data, and added a new transformer to carry out new null functionality.
The list of transformers with null support is, like the formats, listed as an appendix below.
To give you some examples, though, let’s first look at the AttributeCreator.
AttrCreatorNulls
Notice how you can set (or create) a null attribute using the new entry on the drop-down list, or by typing “<null>” into that field. You’ll find you can also do this with other attribute-setting transformers, such as the AttributeValueMapper:
AttrValueMapperNulls
The Tester transformer doesn’t look much different to before, except for rewording the operators to be more precise, but now when you choose “Attribute is Null” it really is checking for a true null value:
TesterNullHandling
Other examples would be the ChangeDetector and the Matcher. The ChangeDetector and Matcher will now truly compare nulls so that “null” is not the same as “missing” as it was before. The change in the parameters here is just the option to turn this behaviour on or off – that way your workspace can be made to run the way it always has (and in fact – for backwards compatibility reasons – it will default to doing so):
MatcherNullHandling
Like I mentioned, other transformers have been updated to better cope with nulls, even if their parameters and outward appearance haven’t changed. For example, the StringPadder won’t attempt to pad a null string, because that would change it to no longer being null. It will still let you pad empty strings, because that won’t affect the attribute’s status.
And then we’ve added a new transformer to handle nulls, called the NullAttributeMapper.
The NullAttributeMapper is a replacement for the NullAttributeReplacer transformer. Basically the function here is to map attribute values to or from null, depending on the original attribute value:
ParkNullExample
For example here, if my ParkId attribute is missing, or is empty, or has a value of 9999, then I will replace it with null. I’d probably do this when I’m reading from a format that doesn’t support nulls, and writing to one that does. That way I get true null values in my output dataset. Similarly I could map null values to an empty field or a specific value:
ParkNullExample2
I probably wouldn’t need to map to an empty field just for a Writer, because if the format doesn’t support nulls, FME will automatically convert null values to something appropriate for the format. But I might do that if I deliberately wanted to give them a new value or make them empty to match other data.
The other great things about this transformer are that it maps multiple attributes, and that it’s not just limited to nulls; so you could even use it instead of the AttributeValueMapper for some scenarios.
EvangelistBanner7
Benefits and Consequences
I think the benefits of this are fairly obvious, so I won’t say anything except that to mention we’ve also updated our APIs to include this functionality too, to ensure developers get the benefits as much as regular users.
However, you do need to be prepared for the effect of reading nulls as “real” attribute values, rather than as a missing attribute.
Many transformers will ignore missing attributes, and you may have come to rely upon that behaviour. But that data might be read as a null now, and that’s going to be treated differently. For example, the ListElementCounter won’t include attributes that are missing. It will, however, include nulls – because these are real values. The two transformers that I think need most careful scrutiny are the Tester and the FeatureMerger.
With the Tester you might check for an attribute that is empty (attr=””) or that “doesn’t exist”. In FME 2014 that attribute might now be read as null instead; in that case the test would fail, where it passed before. Basically, the functionality is better in 2014, it’s just that you’ve come to rely on the older (less good) behaviour. In this scenario you could change the test to be “Attribute is Null” instead. Otherwise, the new NullAttributeMapper transformer can be inserted to change nulls to missing and so revert the behaviour.
For the FeatureMerger, think of what happens when you merge attributes from one feature to another, particularly when a “requestor” attribute has the same name as a “supplier” attribute. The requestor attribute will be overwritten, except for where the supplier attribute is missing. But now, if your missing records are represented as nulls, that requestor would get overwritten as a null. Again it’s because null is a “real value”, and again the NullAttributeMapper can be used to workaround this.
Yes, cases like this are going to be fairly rare and obscure, but it’s worth being aware of them. We’d like you to embrace the new behaviour, but if you want to revert then use the NullAttributeMapper. Basically if you put a NullAttributeMapper into your workspace, directly after your Readers, and map “Null” to “Missing” then the behaviour in the rest of the workspace would be the same as before (although it wouldn’t be as good!)
For the latest info on null behaviour (and the formats/transformers supported) see our null support page on FMEpedia.
EvangelistBanner7
Conclusion
I think this update is going to be oh so useful to many of our users. Our developers have done a super job implementing this big change (any time you update the core data model it’s a big change) and then incorporating it into all these different Readers, Writers, and transformers.
If you notice any parts that could be improved (either functionality or user experience) then please do let us know about your experiences (good or bad).
NewBlogSignature
EvangelistBanner7
Appendix 1: List of null-complete formats:
Appendix 2: List of null-support transformers (ones with exposed null parameters or functionality):
NB: Do be aware that many other transformers will now handle nulls without parameters; for example the Logger will log null values, the InlineQuerier can handle null values in its database, the ListHistogrammer will count the number of nulls, and so on.
About FME Attributes Data Validation Databases FME 2014 FME Evangelist Geodatabase NULL Oracle PostGIS SQL Server Tester
Mark Ireland
Mark, aka iMark, is the FME Evangelist (est. 2004) and has a passion for FME Training. He likes being able to help people understand and use technology in new and interesting ways. One of his other passions is football (aka. Soccer). He likes both technology and soccer so much that he wrote an article about the two together! Who would’ve thought? (Answer: iMark)
Comments
7 Responses to “FME 2014 Sneak Peek: More Ado About Nothing”
  1. Jerod Sperry says:
    Thank you!!!!
  2. Fred Eichelbrenner says:
    Did you consider developping a connector on http://devnull-as-a-service.com/ ?
    Sorry Mark, I could not help adding this absolutely necessary comment 🙂
    • Mark Ireland says:
      No, to be honest I’d prefer to see a recycling service! We shouldn’t be deleting good geographic features that can be used again. Remember: reduce-reuse-recycle.
  3. Peter says:
    Hello,
    I’ve been looking at one of our FME 2013 Workbenches in FME 2014 and I use a tester to test that a database field value is present with the name of the field provided by a user parameter. In FME 2013 I was using the Attribute Exists operator and in FME 2014 this has become Attribute Exists And Is Not Null. This operation doesn’t appear ordinarily though and if you change it to something else you can’t set it back to Attribute Exists And Is Not Null.
    I just wanted to check I am still using this correctly? It seems to be giving the right results still… If I use Attribute Is Null then it fails because I think it is checking if the user parameter is null.
    Thanks.
      Hi Peter,
      “Attribute Exists” would mean that the attribute would not be present at all on a feature. I believe if an attribute was null (say in a source database) it would fall under the exists test, because we didn’t have true null support.
      Now we’ve added proper null functionality then that test would be renamed as you described (exists and is not null) to be sure the user understands that null is no longer included; i.e. the behaviour has changed. So, it depends what you are testing for. If it’s missing attributes you can leave the old test or change to the new one (“is missing”). If you want to find null values the new test is “is null”.
      I’m also pushing development to add a new operator like “exists” that means “attribute exists, is not null, is not missing, and is not an empty string” – we’re just not sure what to call it yet.
      Hope this helps to clarify,
      Mark
  4. Mark says:
    Just found in FME 2014 that an Oracle Non-Spatial writer with the Format Parameter ‘Writer Mode’ set to UPDATE doesn’t update a value to NULL when it has no value on the feature compared to FME 2013.
Leave a Reply
Your email address will not be published.
Related Posts
