Downloads
About the FME Exporter for Autodesk Revit
The FME Exporter for Revit is a free Add-In for Autodesk Revit that allows you to export Revit models as .rvz files. These .rvz files are essentially an IFC export, enriched with additional data, and can be used within your FME integration workflows. (Note: while the Add-In is free, an FME Desktop license or free trial is required in order to use the .rvz files within FME.)
FME Exporter Plugin for Revit
Related Resources
